| | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | How close should my gas pedal be to the floor? The accelerator rod on mine stick out of the floor about an inch So not much to max out but carburetor seems like it wide open . I will try to post a few pics
This is no longer fun
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Pics aren't showing.
You can adjust the accelerator rod by the bell-crank on the block. Should be the spot you attach the rod to the bell-crank with a nut on each side. Just loosen one side or the other to achieve the right pedal height. Assuming we are talking about a 235.
What engine are you working on?
58' 3200 235 3-speed/OD
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Pics aren't showing.
What engine are you working on? A 57 235 in my 52 added Fenton headers
| | | | | Joined: Jul 2000 Posts: 2,198 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,198 | I believe that the installation of a newer engine requires a longer accelerator rod. My '54 has a '62 engine. When they installed the new engine they lengthened the rod.
The rod sticks out 2 1/2"
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | I believe that the installation of a newer engine requires a longer accelerator rod. My '54 has a '62 engine. When they installed the new engine they lengthened the rod.
The rod sticks out 2 1/2" Was thinking just add to it keep it simple I guess
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Linkage issues fixed and working well just need a heavier return spring.
