5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
#1415507 07/01/2021 10:54 AM
1955 Chevy 6400 first. I replaced the vacuum hoses from the axle shifter mounted on the frame in front which is controlled by a knob on the dash. The only problem is that I can't remember which is the high and low connection on the axle unit. Is the top inlet high gear?
Curmudgeon
Curmudgeon
I don't know if this is any help.
http://chevy.oldcarmanualproject.com/parts/1929_54/362.htm
Being I'm not up on how 2-speed works, I would just connect them and try? If wrong swap hoses?
That's what I would do... thumbs_up
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The top half of the diaphragm pulls up on the diff shift mechanism for high speed.
The bottom half of the diaphragm pulls the diff shift mechanism back down for low speed.
This explains why people say to put the diff back in low speed when parked. Because if the shift rod drops out of high speed due to gravity and bumping around when loading the truck it could end up in neutral and you might find your truck at the bottom of a hill.
