1 members (Bill Hanlon),
156
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Found on way to work, a 49 4400 Chevy. Shined lights on it, to see at night. Looked pretty good, couldn't see inside too well. The seat wasn't even tore up, from what I could see. Looked pretty solid metal. On phone, owner says runs, drives and one rear wheel locks up when backing up. Has a five window cab too! Gonna check it out tommorrow. $1300 he says. If good, gonna get it. I miss my 54, wish I had kept it. But then will have to start all-over again with changes to make daily driver, durnnn! I'll let you know what I see in light of day! Hopefully I can say "I'm B-A-C-K!" again. Sure glad I gave up the old truck habit, NOT! Been driving my tilt cab 69 GMC now, with Diesel and just picked up an IH Cargo Star COE to work on too. It's a 75' model, "new", but far from a working truck now.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Have at 'er, GL!! Only the coolest people have '49 4400's, you know so excellent find Keep us posted! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Go for it G.L., you need another Advance Design Truck. My first "Big Bolt", was a '49 Chevy 4400, with 13000, act. miles. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Well.....looked at truck today. Wasn't really as nice as I thought. Someone repainted, green of course, kinda ruff, and inside too, plus black on doors. Seat has new cover, just didn't fis any padding or stuff under it, sheesh! All glass good. Tires are 7.50 x 20's hard and old, but have tread. Fella was there jumping it, and said couldn't get it running, was dumbfounded. It would fire, just not go. He messed with plugs and wires some he said. I called home and got firing order from Ma, and got that straight. It now started and ran, but still wanted to pop some and seemed weak. I turned Dizzy some to get best running. Doesn't burn oil that I can see. He said cause it didn't run as well today, and I messed with it for him, he'ld knock another $100 off price. SO, put some money on it, going back with rest soon and now it's mine. Lots of little things, the door panels are gone, even the little covers for the hinge at bottom are gone. No key, just turn with tab on switch, backwards at that. Not sure what that's about? Hope to be able to drive home, can go back roads. The clutch pedal is halfway down, catches right away, the outer side vent is kinda bent, stays open some, doors rusty inside at bottom, lots of little things. Ought to keep me busy and "Hardware Poor" for awhile! The bed is homemade, but heavy, mostly wood. It's about 12ft, maybe, but frame is shorter by 3ft or so, so may cut it down and make it dump. Well, guess I'll be back more as I go on it. ONe thing I'm not crazy about is the park brake cables are broken, and go into drums. Wish was on the trans like bigger ones had. Much easier to fix. Maybe I can find a trans brake and change to it. And, I sold one of those last year when I cleaned house! Durn!
