0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Hello All, A basic (probably dumb) question, probably covered before. I looked at John Millerman's article in Tech Tips on identifying different models of Advanced Design trucks. I want to be able to tell a half, 3/4, one ton chassis from each other. I notice the lengths of the chassis are different, except there are one tons and 11/2 tons of the same length. I want to find a chassis which will fit with a 14 bolt rear end, and Grigg's articles on using a 14 bolt specify a 3/4 or one ton frame, not a 1/2 ton or 11/2 ton frame. If I was looking at two bare rolling chassis, one and 11/2, next to each other, it would probably be easier to tell, but I have never seen that before. Just trying to avoid buying something I can't use. Also, will the "forward control" chassis be obviously different than a standard frame of the same size? So, how do I I.D. a one ton vs. a one and a half ton of the same length, to try to get something to match up with a 14 bolt rear end? Thank you for any info. on this issue. Love this whole discussion group! Mike Stone. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The position of the steering gear and the angle of the steering column on the forward control chassis will be noticeably different (much closer to the front and more vertical). That's because of the radically different position of the driver's seat. A 3/4 ton and a 1 ton chassis will have 8 lug bolts on the wheels, and 17", 18", or 19.5" tires- - - -1 1/2 ton and bigger rigs will have 20" or 22.5" wheels and a different number and diameter of lug bolts- - - -5,6, or sometimes 10 lugs, depending on the specific build sheet for the truck. Jerry
| | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | The Factory Assembly Manual has detailed drawings showing the dimensions of the various frames. Take a tape measure with you when you go shopping.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Thank you for the replies! I will gather a set a the various assembly manual diagrams. | | |
