3 members (Oswald, Hotrod Lincoln, 1 invisible),
79
Mod | | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 52 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 52 | Ok I can’t find anyone who does sand blasting in my area. So it looks like I ether go at my frame and other parts with a wire and sanding disc or buy a harbor fright sand blaster. Which is best?
Thanks | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | There are a ton of nooks and crannies in a frame that just aren't accessible to a wire wheel or sanding disk. I would recommend getting a sandblaster. Some of those nooks and crannies can't really be reached with a blaster either, but it can at least get further into them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2012 Posts: 332 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 332 | you need a LOT of air volume to make a sandblaster work. I'm thinking 3/4" air line and at least a 60 gal tank. good luck
1936 GMC T-14 restro-mod
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 |
Mike
1951 3100 5 window
| | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | you need a LOT of air volume to make a sandblaster work. I'm thinking 3/4" air line and at least a 60 gal tank. good luck I have a small blast gun that says it needs 11 CFM, which is pretty much flat out for my 5 HP 60 gal compressor. It runs OK on a 3/8" air line, although a larger line would help. It's a slow process. I'd hate to try blasting a frame with it. I might be done next fall.  For a frame, the way to go would be a pot blaster or maybe rig up a water blast. I've seen some YouTube videos about how to make one with a pressure washer.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Any powder coaters in your area? They usually sand blast. And if not, they have someone they use. | | | | | Joined: Apr 2002 Posts: 65 'Bolter | | 'Bolter Joined: Apr 2002 Posts: 65 | A small pot blaster will do the job as long as you have a air compressor with enough CFM. Otherwise, its a couple min of blasting and a bunch more min of waiting to get pressure up. I had to get a 14 CFM, 175 PSI, 80 Gal 2 cycle compressor to handle my media cabinets. BTW, do not use silica sand. Use the coal slag (fine grit: black beauty, black diamond, etc). Sold in large bags at tractor supply. Much easier on lungs and metal 1951 Chevy 3100 "Project for my Wife" - Jigsaw Puzzle 1969 Camaro SS350 convertible 1969 Camaro 327 convertible
