7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible), 92 guests, and 3 robots.
Topics128,265
Posts1,058,360
Members48,485
#1414543 06/22/2021 4:48 PM
Ok I can’t find anyone who does sand blasting in my area. So it looks like I ether go at my frame and other parts with a wire and sanding disc or buy a harbor fright sand blaster. Which is best?
Csims #1414547 06/22/2021 5:29 PM
There are a ton of nooks and crannies in a frame that just aren't accessible to a wire wheel or sanding disk. I would recommend getting a sandblaster. Some of those nooks and crannies can't really be reached with a blaster either, but it can at least get further into them.
Csims #1414574 06/22/2021 8:19 PM
you need a LOT of air volume to make a sandblaster work. I'm thinking 3/4" air line and at least a 60 gal tank. good luck
1936 GMC T-14 restro-mod
Csims #1414581 06/22/2021 9:43 PM
Csims, check your PM.
Mike
1951 3100 5 window
FAST55 #1414591 06/22/2021 10:48 PM
I have a small blast gun that says it needs 11 CFM, which is pretty much flat out for my 5 HP 60 gal compressor. It runs OK on a 3/8" air line, although a larger line would help. It's a slow process. I'd hate to try blasting a frame with it. I might be done next fall. grin
For a frame, the way to go would be a pot blaster or maybe rig up a water blast. I've seen some YouTube videos about how to make one with a pressure washer.
Csims #1414605 06/23/2021 1:33 AM
Any powder coaters in your area? They usually sand blast. And if not, they have someone they use.
Csims #1414655 06/23/2021 2:23 PM
A small pot blaster will do the job as long as you have a air compressor with enough CFM. Otherwise, its a couple min of blasting and a bunch more min of waiting to get pressure up. I had to get a 14 CFM, 175 PSI, 80 Gal 2 cycle compressor to handle my media cabinets. BTW, do not use silica sand. Use the coal slag (fine grit: black beauty, black diamond, etc). Sold in large bags at tractor supply. Much easier on lungs and metal
1951 Chevy 3100
"Project for my Wife" - Jigsaw Puzzle
1969 Camaro SS350 convertible
1969 Camaro 327 convertible
