| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 34 | I have a 55 second series truck with a 1978 Camaro front suspension. Disk brakes in front and drum breaks in the rear. The master cylinder leaks from the cover. I have replaced the gasket and it still leaks. Could it be the proportioning valve? The breaks work fine. | | | | | Joined: Feb 2004 Posts: 29,809 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,809 | Don't overfill the reservoir. A little air gap below the gasket is called "expansion space"- - - -particularly on a non-vented system. Jerry
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Might be. Those proportioning valves have a shuttle cock inside that acts as a trigger for the brake light sensor. It also stops fluid flow if there is a failure in the brakes, say a rear wheel cylinder fails, the loss of pressure forces the valve to close as to the rear brakes. That may be the fluid out of the cap or it could just be as HRL noted, that you are overfilling the master.
Just as an fyi on the proportioning valve, one of the issues is that to bleed the brakes, you actually have to remove the brake light switch and insert a small tool that keeps the brass shuttle cock centered. otherwise when you crack open a cylinder or caliper, the loss of pressure moves the shuttle cock and you have to then get it re centered. I just went through this same thing with a ford truck that had essentially a chevy brake system on it. We discovered the rear brakes were not working and the shoes were in such good condition it looked like they had never worked, although the owner, the uncle of a friend of mine, swore up and down the truck stopped fine. It ended up the valve had tripped and was in the tripped position so long it was now simply corroded in place. The rear brakes had not in fact been working at all. Replaced the valve and properly bled the brakes and the truck stopped like is should.
Mike
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Great topic! Will a continuity tester across the switch confirm if the shuttle is centered or not? If it's not centered how do you re-center it? Thanks, Mike B  | | |
