6 members (Hotrod Lincoln, GMCJammer51, jmoore, Forty9, 2 invisible), 117 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
#1414039 06/16/2021 2:27 AM
Did the original 3 speed transmission have synchros. Also what is the designation of that transmission. Thanks for any help.
Second and third gears were synchronized in that series transmission. It is known as an SM318 which was also the designation for the later open driveline unit. Most parts don't interchange with the later version, however.
Fred
Moderator, Electrical Bay
And if you have a pickup in which the prior owner routinely used 1st gear as a downhill brake, that gear will be worn very oddly...making it howl loudly all the time and jump out of gear on acceleration. Good luck!
~ Jon
