8 members (Oswald, Hotrod Lincoln, moparguy, tclederman, 2-Ton, 1955 1 Series, Shade Baby, 1 invisible),
324
Mod | | | Forums66 Topics128,162 Posts1,057,056 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Short story: After a few tanks of gas idling in the driveway, and a about a dozen short spins around the neighborhood, finally decided to take my '53 235 for its maiden voyage into town.
She ran like a champ!
Over two days, I put about 100 miles on her: lots of stops for shopping, started every time. Loving life. Even hit 55mph on the highway on the way back from the dump (with a tailwind).
Feeling bold, I decided it was time to take my lady for ride on day 3 -- rather than have her sit by her phone ready to come meet me with a tow strap.
Eagerly, (perhaps too eagerly?) we jumped in, fired her up (sounded great), didn't let her warm up like usual, and backed out of the driveway. Made it 200 ft down the road. Then she died.
She turns over, but only stays running if I'm almost flooring it, and only then she has a loping along, forcefully belching black exhaust. Forget getting her into gear.
My lady walks back to the house for our other vehicle and tow strap (she's a good woman).
Figuring it was flooded, I let it sit overnight in the driveway. Same symptoms the next day.
Noticing my inline fuel filter just before the carb was full, rather than half-full like usual, I thought maybe there was too much fuel gong in. I tried pinching off the gas line going into the pump to reduce gas intake. Same symptoms.
I had a spare set of plugs on hand, swapped them out. Same symptoms.
(A note on the plugs: after turning over for less than a minute (again almost flooring it to keep her alive) the plugs were surprisingly sooty. Well 3 of them were sooty, 1 looked good and 2 were wet with fuel / maybe oil.)
So, still working on the flooded theory, I left the plugs out last night and am going back to it this afternoon.
Any thoughts on what else I should / could be checking?
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | What position is your choke in?
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Choke works. Closed it won't start. Full open the engine catches -- albeit with the issues above. If I close it after I get it started, it dies.
| | | | | Joined: Mar 2014 Posts: 4,509 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,509 | Timing? Did you hear any funny sounding noise? You might try to check timing...if only statically. If you have a fiber camshaft gear it is possible it sheared off a tooth or two. Also possible your distributor was loose and shifted position. Carburetor? Rochester? Have you worked on it? There is a chance the float has failed or stuck...needle could have also stuck open. Look down the throat with the choke open. Do you see raw gas in there? Is there fuel on the manifold gasket or at the point of the throttle butterfly shaft?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Thanks JonG, I'll track these down. Recent carb rebuild, and timing... but the distributor shifting is not unlikely.
| | | | | Joined: Apr 2021 Posts: 41 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 41 | Hey ThreeTree, I am a rookie here and would not usually have anything to offer - except that a similar pattern just happened with me. 1950 GMC 1/2 ton with 216. Ran the best it ever did - took her for a "big" 50 mi trip smiling all the way. Then a week later very hard to start, ran really rough & needed high RPM just to keep ticking. Compression test on #5 cylinder was zero - ended up being a broken intake valve spring. Plug on that cylinder was really dry sooty. Hope for your sake it is something better - but worth checking the compression. G' luck Jim
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Thanks GMJim - I've been avoiding, but expecting a more in-depth rebuild... so wouldn't be surprised. Good lead! Thanks. And funny how that "smiling all the way" suddenly can turn into a :-|
| | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Sounds like the float in the carb is stuck open to me. The wide open to keep it running and the belching black exhaust are the clues.
If its a Rochester, the float may be rubbing on the casing causing it to stick. The needle valve on the float may also be stuck open.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a piece of foreign matter in the needle & seat. Try this. Pinch off the fuel line with vise grips. You pinched it before but you evedently didn't get it tight enough or it would stop flooding. Start the engine & run it till it uses up all the gas in the carb. & starts to die. Take the clamp off & try it again. Often that will flush the dirt on through & solve the problem. If not you will need to take the carb apart & check the float & clean thr needle & seat. Often the float leaks & gets full of gas. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Are you seeing gas pouring out of the side of the carb? A stuck open float valve will cause the overflow to leak out around the throttle valve shaft It would help to know which carburetor you have.
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Just back from vacation and finally getting brave enough to track this down. Turns out it may be simpler than I feared! The metering jet had shaken loose and was floating in the bowl.  Quick question: is loctite on the metering jet a bad idea? I'm still playing around with size of jet so not sure I'm ready to commit to one, but it's running smooth at least when the darn thing stayed in it was...
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | And it's a Rochester single barrel.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Unless something is really messed up, I don’t see why you’d need the loctite.
And my hunch is that the loctite has a greater chance of doing harm than it does of doing good.
Someone with direct experience can correct me.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I don't think LocTite will survive constant submersion in gasoline. Either the threads of the jet or the metering fixture are worn, or the jet needs to be tightened a bit more firmly. That assembly will stand a pretty firm torque without getting damaged- - - -just be sure your screwdriver is a really good fit in the slot of the jet. Jerry
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Don't settle for "close enough" with the screw driver fit. Make it perfect on the bench grinder.
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Thanks! Feel like it's pretty torqued... At least I know how to field repair it if it happens again.
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | ThreeTree53, I just sent this date a thankyou to JonG, Check out the great info he sent to me . Doc.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Three tree 53 This isn't your trouble but might be a tip to remember. Old mechanic I worked with would have people come to him broke down along the road,he would say did the wipers fly-up on their own ?? If yes-he would say timing gears let go !! Puts pressure in the intake,may bend valves !! | | |
