Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, farmallb, TooMany2count), 65 guests, and 1 robot.
Topics128,006
Posts1,055,272
Members48,418
Hi everyone,
New to stovebolt, I just started restoring a 1950 Chevy carry all, it has a 350 with 4 speed. My dad drove it as his daily driver back in the mid to late 80's It's been in our family since it was purchased brand new. I'm changing the front end with a newer style. Getting rid of the huck brakes. My question is I'm looking to upgrade to power brakes but the description in the unit says it won't work with a manual tranny. It has a 4 speed truck tranny out of a mid sixty's truck. Was just wondering if it won't work with original trans but will with newer standard. Or what mods I need to do to make it work. Also it has the clam shell style back doors, I have a parts carry all with barn style. What style would be better..I really don't care about ease of loading - unloading.
Thanks any info would be appreciated.
Big Bolt Forum Moderator
welcome to the site! I am not sure either style is necessarily "better" than the other. I had a Willys wagon with the tailgate (similar to the clamshell on the burb) and my 59 Suburban had barn doors. Each had benefits. Barn doors were way nicer for loading groceries, but the tailgate was nice to drop down and put a camp stove on or use as a table for whatever. On the Willys, the tailgate was rated for 500 pounds!
AS far as the brake kit, I am assuming it is one that goes on the frame where the stock master cylinder goes and it will hit some linkage. You might need to call the place and find out. Maybe you can just move it back a few inches?
Mike
Just as a point of clarification “Carryall” is the GMC designation and “Suburban” is the Chevrolet designation of the same vehicle.
That sure looks like it is still real solid! And a family heirloom as well. Can't beat that. I'm sure you will get a plethora of ways to improve your truck, regardless of what you call it.
Another quality post.
Real Trucks Rattle
1949 Suburban Carryall (3116 & 3106)
And, again: 1954 Chevrolet 3106 & 3116 Suburban Carryall
Let's play together nicely.
Suburban is still the first word in the Chevy version but I stand semi-corrected!
hmmm - what's your point (the first word - Carryall - 1934)?
It seems like GMC used the same name a few years later (1937) , as a "Johnny-come-lately" ("a newcomer to or late starter at a particular place or sphere of activity").
And we’re going to believe Wikipedia? My point Mr Curmudgeon is all my adult life GMC people have called their vehicles Carryalls and Chevrolet people have called theirs Suburbans. Which is formally correct and which is old wives tales, does it really matter? Mr Johnson has a nice Suburban and he should be proud of his project and he can call it whatever he wants.
Back to the OP’s questions. Careful positioning of the underfloor master cylinder and maybe a bit of fabrication on your part and you can make it work. Since you have already modified to a V8 why not just put a power brake unit on the firewall like the later trucks? I believe the clam shell doors might be a bit rare compared to barn door, plus you can “Tailgate” with the clam shells. JMO
The master cylinder DOES NOT have to be in the factory location. It can be moved back to an open space and a longer push rod used or it can be remote mounted ANYWHERE. If moved back you will need a new hole in the floor for a filler plug or just fill from underneath with a mirror and douche ball. For remote mount the factory mc line runs to a slave cylinder which moves the rod to the booster/mc. The remote unit can be in the bed, trunk, cab, anywhere. Look at a 1957 T-Bird, it has the mc on the firewall and the booster/mc on the left side of the radiator.
Evan
You could use a newer transmission with hydraulic clutch on the passenger side if linkage interference is the issue.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
I think they make those for older transmissions, too. I just installed one on a top loader. Plumb it to the left or to the right. As long as the bleeder is up!
Change to a firewall unit with hanging brake pedal seems easiest way. Everything is under the hood, easy to check fluid & monitor everything.
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
I prefer the barn door style, mostly because I think they look better. They're easier loading also, especially since they can swing fully open.
That being said, the clamshell doors had lower production numbers, therefore are rarer and probably more valuable. Parts may be harder to find however. It's also a one-piece glass (no center divider) for better rear visibility.
1951 Chevy Panel Truck
