4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 125 guests, and 1 robot.
Topics128,109
Posts1,056,271
Members48,439
There seem to be quite a few subtle identifiers for each model year. 1948-1951 AD"s. Not so much that I can find for 1952 vs 1953.
Korean War caused some changes from earlier years, was that for both '52 and '53? Any easy clues between '52 and '53?
A few differences between 1952 & 1953 USA Chevrolet trucks.
"taken from the Light Commercial Vehicle Association (LCVA) - Mar/Apr 1984"
Let's play together nicely.
There's this from the tech tips page here on Stovebolt. But it's missing the painted bumpers and hubcaps that were used on the Korean War year (52-53) trucks in lieu of chrome. It only identifies the hood badge difference between 52 and 53.
Didn't clothe wires go away in '53?
Carl,
I think the factory was trying to eliminate the fabric covered wires in '53, but must have been using up old stock? Clearly, '53 was the transition year. My '53 Bel Air (an early to mid model year build) has most major portions of the mid-current main harness that are plastic insulated, but the high current and outermost sub-harnesses (eg headlight wiring) are cloth covered. I can't speak to the '53 AD trucks, but I am guessing the same - portions of the wiring harness in both styles - probably depending on when during the '53 model year the vehicle was built.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Thanks for the responses. Looks like the hood badges are telltale, although they are easily and often swapped.
I need to work on my search skills. Knew the tech tips were there, but always use the "hop to" drop down menu to change forums and "Tech Tips" don't show on there.
My list of AD changes.
My Blog
AD Addict & Tinkerer
Awesome!. Thanks Dave! Just saved a screenshot to my iPad. Thats about as simple as it comes.
Phil
Project Journals
Stovebolt Gallery Forum
thumbs_up
My Blog
Saved your great post as well. On under bed spare tire carrier, what year did they change from the hook style hanger to the threaded rod. Thanks.
1952 Chevy Pickup Truck
Moderator, Electrical Bay
For a specific accounting of what was in your particular truck, go here:
https://www.gmheritagecenter.com/do...hevrolet-Trucks/1959-Chevrolet-Truck.pdf
You can also find torque and horsepower curves for your particular engine. Those are very interesting as they reveal the effect of changes between years. If you look far enough, you can also find GM published data about why they were making the changes.
Where the year shows (1959 above), type in the year of your truck and then hit the "enter" key. You'll see what GM published in the year your truck was built. There is also tons more information on the GM Heritage site. If you want a sales brochure (most are in color) for your truck...they're there. Example:
https://www.gmheritagecenter.com/do...hevrolet-trucks/1952-Chevrolet-Truck.pdf
Good luck.
~ Jon
24601
Thanks for the shout out, Kevin. The article is missing a lot of things but I put it together as a quick spotting guide for use on the fly in junkyards, backyards, etc. It is not intended to be an indepth piece.
Jus sayin ...
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
No worries, John. It's a handy item, and since hubcaps and bumpers are not necessarily found on a lot of survivors, it gets the job done. thumbs_up
