7 members (Jon G, papas52, Peggy M, Hotrod Lincoln, ronsway, 2 invisible), 80 guests, and 4 robots.
Topics128,087
Posts1,056,340
Members48,442
I know my truck was originally a 6 cylinder. I keep reading that there are different U joint sizes for some trucks that had "heavy duty" transmissions. Anyone know which ones I need?
I need to replace my PG rear seal, and thought it might be good to do the U's while the driveshaft was out.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
ASU Offline
My experience has been that U joints are fairly generic. Pull the old one out and take it to NAPA, or an "old" parts store. they will measure cap diameter and distance across the caps, and give you the correct one. If you want to measure yourself, do a quick internet search for universal joint dimensions. https://www.currieenterprises.com/understanding-u-joints
As with all of our trucks, you never know what was changed since new!
Jon
Jon
Very true. In my area, most of the "old" parts stores are gone. I have to deal with AutoZone and Advance Auto. Sometimes Pep Boys works as well, but they seem to be going under frown
I just placed my order with LMC Truck. They had a pretty good diagram to help identify what my truck most-likely has. I ordered both options for the front U joint, in the event that anyone got, uh, "creative" with my truck in the past smile
Jon
That’s what I did when I did mine. The kids at “O” or “Auto” will look at you like a pickle is growing from your forehead if you ask them to measure the U joint. But if there is a store in your town with an actual Parts guy....he will fix you up in no time.
On the other hand, if you are pretty confident that all your setup is original....then you will probably be fine with the LMC approach. I’ve had good luck with them as a supplier.
1951 3100
Thanks for the feedback. I'm not sure if theirs come with the grease fitting on them for lubing or not, but as rarely as I will drive this truck, I'm not overly worried about that.
You could take your driveshaft to a driveshaft shop and have them check balance, replace the ujoints.
Interesting suggestion- I'm not even sure where one of those would be around here.
Insomniac
Insomniac
A good transmission shop may also do driveshafts. At least they will know where to go. Chances are that you don't have the original rear end and they could confirm that.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks- I'll have to get some pics of it. It does look "purdy old", though grin
I just don’t mess with joints anymore. We have a couple of longtime very reliable very reasonable driveshaft shops in OKC. I just drop the shaft off and tell the guy I want new heavy duty greasable ujoints. He calls in a couple of day, if not later that day, and I go pick the shaft up. No worries on fitment and they check the balance while they have it. Google “Driveline Shop” for your area. Bet there’s one closer than you think. Good luck
pan31man Look at a 369 u-jointat NAPA that is same as a 57 chevy,if you change them have your grease fitting leaning toward the center of the driveshaft so you can grease it.
