7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Installing a new rockers set on the ~'53 235, and notice that one of them (just one) was machined a little off, so instead of hitting the valve stem dead on, it's off to one side:
(___) | |
Instead of
(___) .| |.
I'm sure that's not ideal... But how bad is that really?
It's flush with the valve stem -- meaning the entire valve stem is touching the edge of the rocker. Just not centered on the rocker.
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
| | | | | Joined: Feb 2004 Posts: 29,753 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,753 | It's a lot more likely that during a valve guide replacement some time in the past that the guide was installed a little bit crooked, or maybe the guide is badly worn. What's the compression on that cylinder compared to the rest? Which valve is it, intake or exhaust? You can check for a worn guide by packing the cylinder full of small-diameter rope to prevent the valve from falling in, turn the piston up tight against the fill rope, remove the valve spring, and check the guide for wobble by shaking the stem from side to side. Jerry
| | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | Great tip!
However, I'm certain it's the rocker. If I swap it with its siblings, the problem follows the rocker, and the sibling lines up fine with the valve stem.
It's LH Intake.
| | | | | Joined: Feb 2004 Posts: 29,753 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,753 | OK, looks like you've got a badly machined rocker, then. I'd recommend trying to replace the one that's not aligned, since the oddball geometry will eventually cause some uneven wear. I see single rocker arms on Ebay occasionally, or you might want to make a post in the "parts wanted" forum here. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | |
