Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (DirtTaxi, 1955 1 Series, 50Chevy3100, TooMany2count, Leo, 2 invisible), 564 guests, and 1 robot.
Topics126,781
Posts1,039,297
Members48,100
Most Online2,175
Jul 21st, 2025
I have another question, this time regarding the correct donut gasket on a 235 cid that goes between the exhaust manifold and the exhaust header pipe. I have tried several donuts and have had trouble sealing off the exhaust system at the joint. Does anyone have a solution? Looking at the old header pipe it seems like there might be remnants of something that looks similar to a rope gasket in the recess of the header pipe, probably made of asbestos. Anyway, I would be interested in hearing about solutions and possible workable part numbers for the stock exhaust on a 1955 235 engine. I thank you all in advance.
1941 Chevrolet AK 1/2 retrofitted with a 235 engine
Moderator, Electrical Bay
Usually the gasket you get with a full gasket set will do it fine, or you can purchase these separately from nearly anywhere. You know the exhaust pipe slides into the manifold and there's a lip on the exhaust pipe that mates with the exhaust manifold and a separate piece slides up and holds the donut seal in place, yes? Two threaded studs coming out of the manifold mate with this piece and it simply tightens up against the donut. Take a look at the image below. Hopefully it will be self-explanatory.
~ Jon
This one should work...https://www.rockauto.com/en/moreinfo.php?pk=11478469&cc=1487268&jsn=410
~ Jon
AD Addict & Tinkerer
Jon, your link doesn’t work.
Phil
Project Journals
Stovebolt Gallery Forum
Drag your cursor through it, highlight it and then right click to get the option "go to...."
Sorry, but I have no control over the script the site is running. Sometimes links work and other times, they seem to go a bit wonky. Could be me, also or the way I put it into the sentence. Let's try this:
~ Jon
I tried dragging and dropping but to no avail. That last one works.
My gasket on my ‘59 235 is different. It’s flat instead of the donut style. Although the manifold uses a donut style, the flat flange on the pipe does not. More that likely, the muffler shop used by a PO, used what they had on hand, instead of obtaining the proper flange. For now it doesn’t leak but I suspect it may have to be changed in the future.
Phil
Project Journals
Use the brass nuts also ,makes it easier when it has to come apart.
kevinski
1954 GMC 9300
Interesting, Phil. That type of gasket isn't used anywhere on mine. I've seen those used plenty of times when mufflers or catalytic converters have been made so they can be removed by un-bolting, but not in AD trucks.
~ Jon
That donut is the standard part and I am using a Fel-Pro equivalent.
However, if you have a poor manifold to exhaust flange fit....there’s another FelPro (for a different application) with the same inside diameter but a larger OD and taller profile. The guys at my Napa store let me wander around in the back one time and we found this.
I’m lousy at documenting this kind of stuff, but if anyone is curious I will see if I retained the package that would have the part number.
1951 3100
My parts stores are not always that accommodating to let me check out their stock. If you do have a NAPA number, I would go and check it out.
Unconventional Thinker
Plug in your info and you can find any part you need for your vehicle. www.napaonline.com
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
That was what I removed during my recent engine rebuild. I tried the donut gasket that came with my Fel-Pro gasket set, and it would not mate against the flat face of the exhaust pipe. For now it works with no leaks, but I know it’s not right and I’ll address it one day.
Phil
Project Journals
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.038s Queries: 16 (0.033s) Memory: 0.6519 MB (Peak: 0.7567 MB) Data Comp: Zlib Server Time: 2025-09-22 21:12:10 UTC
Valid HTML 5 and Valid CSS
