6 members (WICruiser, Greg_H, treegrower, TUTS 59, Gray_Ghost, LAROKE), 128 guests, and 1 robot.
Topics128,105
Posts1,056,543
Members48,448
1950 Chevy 3100 216 3 Speed.
1950 Chevy 216 with stock intake and exhaust
Does anyone have a diagram as to how to set up the duel diaphragm fuel pump to work with the wipers?
I used I have it set up, went to electric, and now want to go back to original.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Here's how I set up mine when I did that.
Would you care to share some pics of your setup?
I think that’s how I had it set up, I just remembered I had the vacuum lines following the fuel line so that in went around the front of the valve cover.
But that was 40+ years ago. The electric wipers got installed 15 years ago. Thanks if you have any pics to share.
Darren
Just curious what happened with the electric to want you to switch back
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Darren,
Maybe these will help you.
Harold
SHA1: 204d16095511de3cb2b0886c0caa426c9fa6e302
Harold
Moderator, Electrical Bay
I'm curious about that also. You knew I posted a bona fide operational wiper delay circuit a couple of years ago, yes?
~ Jon
On mine the rear port connects to wiper hose. The front port connects to manifold. My AC dual pump looks a bit different that the above posted one.(ports). I put a brass elbow on the manifold.
On a side note under the dash I put a "Y" fitting where the wiper hose comes in.
I added a valve and it now runs my small original Trico fan.
Just turn the valve back and wipers work. I love the vacuum set up.
Todd
1950 Chevy 3100
Great answer. This is the same fuel pump I am running. I like the way you ran the rear port around the back of the fuel pump. Details count!
Darren
I've always used the KISS principle. Run the engine- - - -use a gauge on the pump to see which port develops a vacuum. Connect that port to the wiper motor control. Connect the other port to the intake. Think up something else to worry about.
I removed the electric motor because I don’t like the look of the switch on the dash. Switched over to the electric wipers when my boys drove the truck in their high school years. But after I complete my restoration I don’t plan to drive in the rain. If I get caught in the rain the vacuum wipers will be enough. But more than anything it is about the esthetics.
Darren
See my reply to Kevin.
Darren
I like my vacuum wipers which I guess are also electric because I power them with a Mercedes diesel electric vacuum pump mounted where the battery box was. The hose to the wiper motor is in the wire harness and no one notices. Instead of single speed, 2 speed, or 3speed wipers I can have from one cycle an hour to launch the wiper blade like a javelin fast. Pulling a loaded trailer uphill has zero affect on wiper function.
Evan
