3 members (Wheelie, Peggy M, Tom McGrath), 85 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
Hello all, I read that 45’ pickups didnt have a rubber gasket around the gas filler but instead had a metal plate with a “leather” gasket? I took the rubber one that the PO put on and under was the four bolts, and i found the round ring/ plate in a box of parts. So what does the leather gasket look like? is it something someone sells? Anyone have a picture on a truck? Thanks!
I have the original that was on my ‘46. It couldn’t be reused. The metal plate you have can be used as a template to make a replacement. The leather on this one is about 1/8” thick.
Jim Carter had both leather and rubber replacements in his catalog.
