| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2021 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 11 | Hello all, I read that 45’ pickups didnt have a rubber gasket around the gas filler but instead had a metal plate with a “leather” gasket? I took the rubber one that the PO put on and under was the four bolts, and i found the round ring/ plate in a box of parts. So what does the leather gasket look like? is it something someone sells? Anyone have a picture on a truck? Thanks! | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | I have the original that was on my ‘46. It couldn’t be reused. The metal plate you have can be used as a template to make a replacement. The leather on this one is about 1/8” thick. | | | | | Joined: Apr 2005 Posts: 61 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 61 | Jim Carter had both leather and rubber replacements in his catalog. | | |
