1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#1409334 05/10/2021 3:36 PM
I am working on sprucing up my 53 3100 P.U. and trying to determine it`s original color to match the paint . As the photo shows there is "j. Green "scratched into the metal on the passenger side cowl under the hood. Would this have been done at the factory or by a body shop or previous owner? A professional resto guy said he had never seen this type marking from a factory. There appears to be only the original(??) grey primer and topcoat on the truck.as far as layers go. I purchased a quart of Juniper green from Jim Carter and painted the firewall and inside of hood as a test color but appears much more blue green than current color which has seen rubbing compound and wax. Also was the cream colored pin striping at the base of the cab a factory job. just seeking others experience with Juniper Green .thanks all![img]https://www.stovebolt.com/ubbthread...1261/filename/IMG_20210510_080614870.jpg[/img]
1953 3100 Pu
Swami29 #1409362 05/10/2021 6:08 PM
According to the Stovebolt paint tech tip and the '53 Vehicle Info Kit, Juniper Green replaced Forester Green as the standard paint color in '53 and later models, but your truck's original color sure looks like Forester Green to me. The cab pinstriping would have been cream for either Forester Green or Juniper Green. Maybe your truck was an early production in that model year and was painted with leftover Forester Green. ohwell Maybe the painter was Joe Green and wanted to autograph his work. grin
You might try and match it up with Forester Green and see if it's closer.
Swami29 #1409426 05/11/2021 2:41 AM
No matter what, nice color.
Craig
Swami29 #1409597 05/12/2021 12:42 AM
Thanks for the update, will look into the Forester green,I like that as I spent quite a few years working in the Forest with F.S. and Park Service....
1953 3100 Pu
Swami29 #1409874 05/14/2021 9:33 AM
Bond Villain
Bond Villain
Concur with cmayna -- if the green on the cowl is the original paint, then we need to see the rest of the truck! Love the look of aged original finishes like that.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Swami29 #1409946 05/15/2021 2:05 AM
In the 45 years since I dropped out of the corporate rat race and started restoring/rodding cars andtrucks we have probably done several hundred AD trucks with ONLY TWO restorations. This 53 is supposed to be Forester Green and it looks darker than yours. Truck sold within a hour of arriving at swap meet so guess we should have done more.
[img]https://i.postimg.cc/SY9VHsCc/evan-truck-005.jpg[/img]
[img]https://i.postimg.cc/vcR0frwh/evan-truck-004.jpg[/img]
[img]https://i.postimg.cc/qt7w4Q2J/evan-truck-006.jpg[/img]
Does have 235 and passenger side tail light.
Evan
