| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 22 | Hi Folks, Has anyone installed a Tremec 5 speed in their 3100 pick up and used an aftermarket tranny crossmember? I installed the TKO 600 and a dual master cylinder from Performance Online (sits 6" further back to the rear) and of course the stock crossmember won't fit back without major fab work. Has anyone else dealt with this problemo with an aftermarket crossmember? Thanks for any suggestions. Bodini | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Concensus is you don't need a crossmember for the tranny. If that is, you're running a original (or original type) 6 cyl Stovebolt engine. The trucks that came with SM420 4 speeds which is one heavy sucker have no transmission crossmember. It weighs about 150 lbs, a T5 weighs about 75 lbs. Don't know about a TKO 600, but if less that 150lbs and if a Stovebolt engine, I'd just bolt it to the bell housing and call it good.
Now, if running a V8 please disregard the above.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
