1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1409219 05/09/2021 8:31 PM
I was wondering if you put a brake booster and master cylinder under the floor is it hard to add fluid are check it? After putting the floor padding in ?
Easy solution is to add a remote reservoir.
Harold Wilson
41 Chevy 3/4 Ton
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Crusing in the Passing Lane
What size Truck truck are you working with?
Ed
It’s a 52 3100 Chevy. Haven’t gotten that far yet. But wanting to have ideas before hand. Thanks I haven’t looked into remote reservoirs yet.
Another option would be to use a master with a plastic bowl. Then you could just peak from underneath, now and then.
