1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
rad
Offline
1960 235 engine block #3769716 in my 49 3100. It appears to be a truck block. Does it have hydraulic or solid lifters?
AD Addict & Tinkerer
The only way to truly tell is to pull the side cover and look at the lifter. You don’t know what was done to that engine. You can find out for the cost of a gasket.
Phil
Project Journals
Stovebolt Gallery Forum
3769716 is a 1958-1962 235 truck (mechanical lifters) block casting code.
From 1958 on all 235’s are drilled for hydraulic lifters, even if they were not used.
Even a truck engine could have had hydraulic lifters installed at some point.
My Blog
