| | | Forums66 Topics128,290 Posts1,058,567 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14082 07/05/2002 8:38 AM | Joined: May 2002 Posts: 32 Member | | Member Joined: May 2002 Posts: 32 | Hi, I posted this in the lounge, maybe should have tried here. Lost out on the one I was going to bid on, but there is another there, any help?
Well I tracked down my fuel starvation problem (I think). I found a leak on the body of the fuel pump just before the attachment bolts, and think it is either sucking air through here or streaming all my fuel out under load (it does leak at idle as well, but the bowl stays full). I found a couple of fuel pumps on ebay that look exactly the same but state that they are for 37-50 and my motor is a 52 235. Do you folks think that these NOS pumps are just circa 1950 and that's why they state those years or are there slight differences in the body or mounting area that won't work on my motor?
As always all answers appreciated for this newbie,
Lorne
MbOutdoors (Lorne) 1952 Chev 1300
#14083 07/06/2002 6:48 PM | Joined: Jan 2001 Posts: 30 Member | | Member Joined: Jan 2001 Posts: 30 | Call your local parts house or Chevy dealer. You would be surprised how many things you can still get and don't have to buy used off ebay. Check some of the online sources too, if they don't show a different style between 52 and other years, you are probably safe in assuming the same fits both. | | |
