1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | Has anybody used this HEI distributor? TSP Early Inline 6 HEI Distributor I'm really thinking about trying one out. I noticed it has a steel gear which I would assume I would have to use the gear from my old distributor since my cam is cast ('57 235 w/mechanical lifters). The notes indicate that the gear would be most compatible with cast iron cams but I'm not so sure about that if the gear is steel. If anybody has had any experience with these distributors, please share!!
Mason
1947 Chevy 3100 -57 Chevy 235 -95 S10 T5 Transmission -97 Blazer 3.42 Rear End
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I installed one on a ‘62 235 a few years back. Only issue was the clearance from cap to side cover was really tight. No interference just tight. Ran great.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | stlcardinalsguy Have done several using almost any v-6 HEI,most have the same gear chevy used since 37, usually turn it upside down. Make a new stub shaft grind an oil pump tang and just make it like the one you took out. Be sure it has end clearance up and down.Can use a small block hold down,some need a tube to raise it up (use aluminum conduit) raising it up helps on clearance to the side of the engine.You get that perfected you,ll really like it !! Next put it on propane,best thing I EVER done for mine--start,run,never cold natured !! | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Chevy 194-235 Early L6 HEI Distributor SKU JM6516 BE THE FIRST TO REVIEW THIS PRODUCT Would look odd with big cap HEI.
Lots of folks, myself includes run:
www.langdonsstovebolt.com/store/#!/Stovebolt-Mini-HEI-for-GM-216-235-261-&-GMC/p/1222040/category=18665949
For Chevy 216, 235, 261, and GMC 228, 248, 270 and 302 engines. Includes new cap, rotor, and OEM GM HEI (heavy durability) square coil.
BE SURE TO ORDER A STEEL GEAR IF NEEDED! SEE BELOW:
Steel gear is necessary for pre-1954 Chevy and GMC engines with a forged steel camshaft! (add 20.00) (Click link below, for information on how to tell if you have an Iron or Steel Camshaft)
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | Justhorsenaround - Thanks! I haven't seen any reviews or anything at all on the TSP unit. Did you use the included gear or reuse your old one?
I don't really care what it looks like under the hood, everything on the truck is going to end up having a major modification of some sort that will look out of place...function and cost are my most major concerns. I almost pulled the trigger on the Langdons HEI but Speedway has a rebranded TSP 6516 for over $100 lower price. I'm pinching pennies as best I can.
Looks like fixite's solution would probably be cheapest, gonna check into that as well. Looks like one could get a complete HEI distributor for a 250 from RockAuto for around 65 bucks.
Thanks all for the help!!
Mason
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Used the same gear as it came with. No problems.
| | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | Thanks! Gonna give it a try.
Mason
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Martin I always used the gear from any 235,have some running for 25 yrs. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | They are cheap in wrecking yards, make sure to get an even fire one, though.
Ed
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | BC59 I think they look a lot better with the big HEI,I guess its because they run so much better,and start with just a bump,itdoes almost bother the dipstick but that is minor. Make mine out of v-6 car donors their cheap | | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | I have one of those TSP type units that has been sitting here for 10 or 12 years. Those were sold under several different names. I bought it on eBay when they were selling them for $70~80 with free shipping. I used it a while and it worked mostly ok, but it allowed oil to run up between the shaft and the housing and from there it would dribble out from under the cap in a big mess. I figured someday I'd make a seal for that and keep it in case my Langdon's HEI had any trouble (which it hasn't). You know those TSP units were not made in the USA, yes?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | Gonna take the advice of everybody here and stay away from the TSP. Did a little more digging and seems lots of people have problems with the junk electronics...and Jon's oil leak problem. I'll likely go the modified 250 HEI route, try to pick one up from ebay or just get a reman Delco unit. Thanks for all the help guys!!
Mason
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Ed Pruss Just called my local horse weed junk yard V-6 HEI is 50 bucks ! Your choice go take it out ,they even tell you where the bumble bees are...and appreciate you telling them if you hit a new nest!! Great family of junk yard dogs over 50 years going there !! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Make sure it has an Even Fire cap otherwise you will be disappointed.
Ed
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | I use a Langdon mini HEI on my truck. Could not be happier. | | | | | Joined: Apr 2020 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 87 | Ed how do you identify odd or even fire cap?,are the poles not spaced evenly? Just wondering cause did the hei to my 65 292 and runs rough, but start's nice
Karl j Townsend
Karl j Townsend
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Poles, or wire receptacles on the cap must be evenly spaced, odd spaced(odd fire) will not work.
Ed
| | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Odd=fire distrigutors were used on the early Buick 231 V6 engines and had an oddball spacing of the plug wires in the distributor cap. Two wirea sre close togethert, then a wide gap, one wire, another wide gap, and two more close-spaced ones. The crankshaft rod journals are also spaced unevenly. The engines shake on the motor mounts at idle due to the uneven firing impulses. Even-fire distributors have sic equally-spaced plug wtre towers. Any Chevy, Pontiac , or Oldsmobile inline six HEI diastributor is an "even-fire" type. jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | The only reason to run a 90 degree cylinder angle on a V6 engine is for ease of manufacturing. V6 and V8 blocks could be run on the same assembly line without tooling up for 60 degree automated machinery. Modifying the crankshaft throws almost, but not quite corrected the odd-fire situation. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Ed Pruss Have made several v-6 HEI distributors fit the 235,never have even seen that cap you describe thanks for that tip !! | | |
