1950 3600. Looking for advice on repairing this. Seemed like it happened overnight. Its just the clutch, not the brake pedal. Its well greased. Could it just be a bushing or is there more that could cause this on the shaft? My manual mentions " a special shaft spring". Does anyone have an exploded view diagram of this assembly?
Has the clutch pedal bolt come loose from the pedal arm (just in front of the firewall)? Other than a severely worn pedal bushing (which isn't going to happen overnight), that's about the only thing that would allow the the pedal to wobble noticeably.
Here's a pic from the FAM.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
