7 members (Phak1, moparguy, Chooglin, 54farmtruck, 2-Ton, GMCJammer51, WICruiser),
47
Mod | | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 16 New Guy | | New Guy Joined: Jun 2019 Posts: 16 | I have a 1950 gmc 100. Came with a 216 and the block broke. Went on the endless search for a full pressure 235 and came up short. In the process i left a message for a guy i found on the internet (i think his name was tom langdon?). So i wasnt able to find a 235 and i bought and started to build a 283 v8. During the build i get a call from the machine shop that machined my 283 and the old man tells me that he just pulled a full pressure 235 out of some old truck that he put a v8 in. So im like hells ya ill take that and ill even pay you to build it for me (the machine shop is more or less a dad and sons and granddaughters that all drag race and build race cars) so i convince my wife that i need something to put the 283 in and she took the bait and now i have a 55 belair. So uesterday i get a call from the guy i left the message with. He just says hey i dont check my messages very often (like 2 months) but anyways i was wondering if you found a 235. And im like oh ya... found one. Hes all is it a gmc or a chevy?? Im like i dunno... its gm arent they all the same? And he just starts laughing and hes all... no, they arent. Im like what you talking about? He starts telling me all the reasons why it wont fit but all im thinking is i need to find out what i just bought. Buuut the guy that is building it is busy drag racing. So.... exactly how screwed could i potentially be? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A 1950 USA GMC 100 came with a 228 engine.
A Canadian 1950 GMC came with a 216 engine.
If your GMC has/had a 216 engine mounted in it, you should be easily able to mount a 235 (or, 261) in it.
You can get a 235 engine to work on a 1950 USA GMC frame - maybe someone will confirm/correct, and explain how/why?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Well they didn't come with 283's either. So you must have been prepared to do some fab work and find drivetrain parts. This will be no different and maybe easier. The drag racer family will be very good at fabbing up whatever you need. (motor mounts, etc). The gurus here will advise what transmission/bell housing/driveshaft issues you may have. I think the 228 was a longer motor, so you may end up with a larger space between fan and radiator.
A 55 didn't come with a 283 either. But that's OK. Good ol' motor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | So I'm like all, I can believe someone talks like you type, but I have never seen anyone actually type how you probably talk. At first I was like all annoyed and what not, then I found myself entertained. For that, I thank you. Good luck with whatever you end up doing. Plenty of guys on this site will be willing to help you along the way.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | ........... Good ol' motor. Yepper. 265, 283, 327, all run like demon on fire and dependable. It doesn't hurt that parts are easy to find either.
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | I get out of breath just reading a post like that. Toss in a little punctuation and a paragraph or two occasionally! Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Johnny 814 I like your posts so good to hear the clamour it takes to get something done. Others growling around sound like my english teacher !!! LOL . Keep-us posted when you roll 'er thru !!! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Tiny Have a pile of 265,283,327 stuff I keep handy too,along with 216,235,235later,261,also 848 heads. Just put hard seats in a 216 head from the neighbors for my 48 dump truck,good to have a pile there too !! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | All small block GMC 6 cyl. engines are longer than Chevys, until the ‘63 194, 230, 250, 292 engines came out.
GMC engines start the SN with the displacement, I. e. 228xxxx, right side, stamped on machined pad behind the distributor.
Ed
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Estimate relative engine length: number of cylinders in 1 bank × bore pitch, + 1 rod width if 2 banks (use 1.00" for rod width if unknown). Actual length will vary based on bell housing design, accessory drive, etc.
Types in size order, smallest first: V4: 2 × pitch + 1 rod V6: 3 × pitch + 1 rod L4: 4 × pitch V8: 4 × pitch + 1 rod L5: 5 × pitch V10: 5 × pitch + 1 rod L6: 6 × pitch V12: 6 × pitch + 1 rod | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | So I will ask the next question that may be helpful to the op which is does anyone know how to determine whether a 50 GMC is USA or Canadian built?
Mike
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Does it have an ID plate on the door jamb? | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Johnny 814 I like your posts so good to hear the clamour it takes to get something done. Others growling around sound like my english teacher !!! LOL . Keep-us posted when you roll 'er thru !!! The OP hasn't been on site since the thread was started.
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Man, I totally missed that, lol.
Mike
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Leave it to fixite7 to drag up an old post. Seems to take delight in making us all think!
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I think it was a test! Fred
| | | | | Joined: Mar 2007 Posts: 3,444 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,444 | I'm like confused man????
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Maybe we need an “Idiot Light” that pops up and flashes (like those annoying pop up adds) when a thread is older than thirty days! LOL. I’ve fallen into that trap more than once, but on the bright side, It does keep us entertained!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Nov 1995 Posts: 5,740 24601 | | 24601 Joined: Nov 1995 Posts: 5,740 | Yeah, it seems many find us after they have rushed into something, thrashed around a bit and then finally find us and want help getting untangled ...
And also why it is good to be patient with them when they do. Calm them ... we're friends here ... put the credit card down and back away from it ... nice and easy ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
