4 members (cmayna, 1955 1 Series, 55shaker, rick46ia), 81 guests, and 6 robots.
Topics128,022
Posts1,055,352
Members48,420
#1405690 04/11/2021 11:49 PM
I know I should know this, and I did a search, but... What year did the Advance-Design speedometer change to 90 mph? Thanks!
Professional Novice
2 Offline
i don't have the exact answer
1950 is 80 mph
1951 - don't know
1952 is 90 mph
47-51 = 80 MPH
52 = 90 MPH
What RPM would be needed to push a '52 90 MPH if you have a typical rear end and tire size?
What is your "typical" ratio rear end (4.11)?
What is the "typical" rolling-diameter of your (rear) tires (30")?
These "calculators" might help?
Especially the one at the bottom of the page.
4.11 rear end (216.5 engine?)
30" rear-tire rolling diameter?
90 mph?
1:1 final gear ratio with transmission high gear?
= 4143 RPMs - a very high long-term RPM in my world (you'd get maybe 10 mpg? I guess)
You might be interested in this graph - if you have not seen it (and if it pertains to your truck)?
90 mph with bump steering and slop most of these old truck have. better be one straight smooth road. or sitting on a restomod build.
According to the info page in the LMC truck catalog the max speed for a 51 is 80. I have a 51 3600 (according to the vin number in the LMC catalog) and my speedo goes to 90. Take your pick.
The question is how steep a downhill would be needed. wink I pegged the speedo (75 MPH) on my Model A once headed down a hill. It got real scary quick and I shut it down. big_eek
I had my old '63 longbed fleetside up to 135mph "ONE TIME". It was screaming and had absolutely nothing left. I swore I would NEVER, EVER do it again. It was that scary.
Highway 70, heading east out of Denver CO. Long, Flat, and mostly straight. I had a buddy in a 1977 911SC clocking me. I had disconnected the speedo - it only went to 100.
Truck turned into an airfoil and lifted instead of squatting. It was riding at the top of the suspension. It got to about 105-110 pretty quick, but then took forever to creep up on the final top speed of 135mph. These old trucks are not designed to go that fast.
I had a '65 Corvette 327 in it, a TH400, and 3.73:1 gears in the back with 31" mud/snow tires. Calculated out around 5600rpm. Probably a bit more with the wheel slippage factored in. I only know it should never be done in one of these trucks.
That's the way the Model A Truck was as well. Basically floating. Even though it was a brick going thru the air, the front fenders acted like scoops and lifted the front end. I never tried that again, either. WAY too scary. That was back when I was young and stupid. eek
