| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I know I should know this, and I did a search, but... What year did the Advance-Design speedometer change to 90 mph? Thanks!
Professional Novice
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | i don't have the exact answer 1950 is 80 mph 1951 - don't know 1952 is 90 mph | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | 47-51 = 80 MPH 52 = 90 MPH
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | What RPM would be needed to push a '52 90 MPH if you have a typical rear end and tire size? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is your "typical" ratio rear end (4.11)? What is the "typical" rolling-diameter of your (rear) tires (30")? These "calculators" might help?Especially the one at the bottom of the page. 4.11 rear end (216.5 engine?) 30" rear-tire rolling diameter? 90 mph? 1:1 final gear ratio with transmission high gear? = 4143 RPMs - a very high long-term RPM in my world (you'd get maybe 10 mpg? I guess) You might be interested in this graph - if you have not seen it (and if it pertains to your truck)? | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | 90 mph with bump steering and slop most of these old truck have. better be one straight smooth road. or sitting on a restomod build. | | | | | Joined: Apr 2020 Posts: 14 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 14 | According to the info page in the LMC truck catalog the max speed for a 51 is 80. I have a 51 3600 (according to the vin number in the LMC catalog) and my speedo goes to 90. Take your pick. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | What RPM would be needed to push a '52 90 MPH if you have a typical rear end and tire size? The question is how steep a downhill would be needed.  I pegged the speedo (75 MPH) on my Model A once headed down a hill. It got real scary quick and I shut it down.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | I had my old '63 longbed fleetside up to 135mph "ONE TIME". It was screaming and had absolutely nothing left. I swore I would NEVER, EVER do it again. It was that scary. Highway 70, heading east out of Denver CO. Long, Flat, and mostly straight. I had a buddy in a 1977 911SC clocking me. I had disconnected the speedo - it only went to 100.
Truck turned into an airfoil and lifted instead of squatting. It was riding at the top of the suspension. It got to about 105-110 pretty quick, but then took forever to creep up on the final top speed of 135mph. These old trucks are not designed to go that fast. I had a '65 Corvette 327 in it, a TH400, and 3.73:1 gears in the back with 31" mud/snow tires. Calculated out around 5600rpm. Probably a bit more with the wheel slippage factored in. I only know it should never be done in one of these trucks. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Truck turned into an airfoil and lifted instead of squatting. It was riding at the top of the suspension. That's the way the Model A Truck was as well. Basically floating. Even though it was a brick going thru the air, the front fenders acted like scoops and lifted the front end. I never tried that again, either. WAY too scary. That was back when I was young and stupid.
