5 members (Hanks custodian, Mike Roache, FishinToms53, ShopRag, Stovebolt48), 97 guests, and 0 robots.
Topics128,049
Posts1,055,634
#1405543 04/11/2021 4:25 AM
I have a 55 1st series 3600. Today I swapped the non-running 235 for a rebuilt 235. In the process, I replaced the flywheel, clutch, and pressure plate. When I went to replace the clutch, I found that I had the same problem as this user:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1092173
Namely, my fork was very worn and the throwout bearing was very sloppy. I have looked around, but can't find a source of repro parts. Is there a seller of new clutch forks out there? If not, how do you repair one? Weld more material on? I'm worried that the heated metal won't have the same properties as a new part.
Grover #1405565 04/11/2021 12:57 PM
AD Addict & Tinkerer
I would post in the “Truck Parts Wanted” forum for a replacement fork. I’ve always had good luck getting the parts I need. Good Luck!
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1405590 04/11/2021 4:03 PM
Thanks! I'll give it a try!
Edit: Just found a NOS one on e-bay!
I am still curious how to fix something like this since there is a finite supply of clutch forks out there, so if anyone has any ideas, I would like to hear!
Grover #1405631 04/11/2021 6:57 PM
A weld and regrind job would work OK. I've done similar things to a pin on a modern clutch linkage that was worn to look like a football in cross section. It's run for another 100k miles without issue.
Grover #1405642 04/11/2021 7:59 PM
thumbs_up
Phil
Project Journals
