Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Guitplayer, Jason Davies, TUTS 59), 121 guests, and 9 robots.
Topics128,281
Posts1,058,476
Members48,490
#1405537 04/11/2021 2:52 AM
Hey Bolters,
Rebuilding the u-joint on my 46 1/2 ton. I wanted to check to be sure, but I'm thinking the lubrication slots in the yoke should face the transmission?
Thanks.
Larry
46 Chevy 1/2 ton stake - family truck for 78 years
USAF 75-81
That would be my guess. Although it may not really matter. I recall that the rebuild kit I used on mine didn't have grooves like that. I may have to dig it out of the parts box and check again.
Is that the original cross or the replacement? The replacements are listed as fitting 40-54 1/2 tons.
That's a replacement Kevin. I'll go ahead and install it towards the transmission.
Thanks for the response!
Larry
Larry
USAF 75-81
I just happened to dig out my repaired u-joint, and it does have the grooves. I installed them toward the tranny, so I'm pretty sure that's the way it came out, as I'm usually pretty careful about putting things back together the way they come apart.
