2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 15 New Guy | | New Guy Joined: Oct 2004 Posts: 15 | My 1946 Chevy 2 ton truck's frame has an approximate 24" section welded in right behind the crossmember that holds the emergency brake linkage. It seems to have been a relatively professional job. They bolted on 1/2" steel plates then welded them in place. The plates are about 5-6 feet long and around 12" wide. I'm just trying to figure out why it was done. Was it lengthened to fit thier needs or what? I can see no evidence of the frame being warped or twisted. The frame sections which were welded in match perfectly on both ends. So any ideas would be appreciated. Thanks, Frank
1946 Chevy Flatbed 2 Ton Truck 1950 Chevy 3100 5 Window Cab P/U 1968 Chevy CST 1972 Chevy Fleetside Longbed 1992 Chevy Scottsdale Ext Cab 2000 GMC Sierra Ext Cab | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not uncommon for the older truck frames to be lengthened to suit a particular deck arrangement, and some deco models came w/ a heavy 'fish plate' from the factory to increase load rating - my 46 GMC 1½T did
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I used to work at a trucking company where I'd say half the trucks had been lenthened or shortened. All of them in a pro shop. This was 25 years ago and it was common at that time at least in the area I was in.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
