9 members (Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, Ponchogl, HandyAndy, 2 invisible),
191
0
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I have a '60-'62 4x4 carryall frame, but the previous owner had cut off the second set of mounting brackets (where the rear cab mounts of a pickup would be) and welded some brackets there to mount a pickup cab.
I'm wondering if those mounting brackets are the same for all of '60-'66 4x4 carryalls and if they are different from the 2wd models.
If they are specific to '60-'62 4x4 models, I'll be in a tough spot trying to locate another pair, but if there is any crossover with '63-'66 4x4's or any of the 2wd models, it should be a lot easier for me to locate a pair.
I will greatly appreciate any of you guys that have some frames laying around to take pictures of or are willing to crawl under your trucks and take some pictures of your mounts. Or if anyone already knows the answer to this because they have seen all the '60-'66 years and variations.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Have you tried to reach out to 4-5-6 chevy trucks? Tony Smith may have your answer. He does not come onto SB much anymore, but I use him off line for many questions. Otherwise, I can take pictures of 62 2wd sub/carryall in 2 wks. | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Pictures will be appreciated.
I haven't checked with Tony yet
