4 members (Wayne67vert, MickeyP, Otto Skorzeny, Bill Hanlon), 176 guests, and 0 robots.
Topics128,106
Posts1,056,213
Members48,436
#140511 05/08/2005 3:18 AM
Junior Member
Junior Member
Hey, anyone got anything to say on aftermarket overdrives? I`ve got a `50 4400 and am trying to make it go about 55, no faster. I had a `54 F-100 that went that fast, and was happy with that.
Joe
Joe
#140512 05/08/2005 4:24 AM
#140513 05/14/2005 3:48 AM
Cub, I have been doing overdrive research myself, including calls to various manufacturers. Gear vendors stuff if neat, goes behind the existing tranny and actuates electrically. Advance Adapters makes the Ranger unit in a overdrive (27%) or an underdrive. These units mount between the bellhousing and existing tranny and actuate via a customer supplied shifter. They are about half the price of a Gear Vendors unit. They have a bolt up unit for the SM420 tranny. Do a Advance Adapter search!!
Atomarc.
#140514 05/14/2005 5:07 AM
Have you thought about swapping the rear pumpkin for a 2-speed unit? That's what I did on my Fire truck. It had a single speed 7.17:1 and I found a 6.14/8.36:1 2-speed that bolted right in. The total cost for the pumpkin and shift switch was $250 and to have my driveshaft modified to fit the larger 2-speed yoke was about $80. My top speed went from about 53mph to 63mph! My truck has an Eaton rear...don't know what type you have.
Swapping in a complete 2-speed rear (drum to drum) might be cheaper than buying an Overdrive unit.
Mike smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
