| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 3 Junior Member | | Junior Member Joined: May 2005 Posts: 3 | Hey, anyone got anything to say on aftermarket overdrives? I`ve got a `50 4400 and am trying to make it go about 55, no faster. I had a `54 F-100 that went that fast, and was happy with that.
Joe
Joe
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cub, I have been doing overdrive research myself, including calls to various manufacturers. Gear vendors stuff if neat, goes behind the existing tranny and actuates electrically. Advance Adapters makes the Ranger unit in a overdrive (27%) or an underdrive. These units mount between the bellhousing and existing tranny and actuate via a customer supplied shifter. They are about half the price of a Gear Vendors unit. They have a bolt up unit for the SM420 tranny. Do a Advance Adapter search!! Atomarc. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Have you thought about swapping the rear pumpkin for a 2-speed unit? That's what I did on my Fire truck. It had a single speed 7.17:1 and I found a 6.14/8.36:1 2-speed that bolted right in. The total cost for the pumpkin and shift switch was $250 and to have my driveshaft modified to fit the larger 2-speed yoke was about $80. My top speed went from about 53mph to 63mph! My truck has an Eaton rear...don't know what type you have. Swapping in a complete 2-speed rear (drum to drum) might be cheaper than buying an Overdrive unit. Mike  | | |
