4 members (Jeff Ogden, dt235sd, Bwana-Jim, Hugh63c10), 118 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
Is it possible to remove the oil pan and fix the leak without removing the engine?
That is my question!
Elmo!
You are working on what?
1953 3600 3/4 ton chevy!
When you jack the vehicle up, support the frame, not the front axle, with your jack stands. The axle will drop down far enough for the pan to be removed that way.
Thank you Jerry!!
