0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | virginiafiretruck!
For what it might be worth! I had my 46 painted with the 'newest' type of paint, then clear coated. The painter matched the original colour and it was great. He claims it can sit outside for the next 20 years and not fade etc. I don't think you'd hurt the 'originality' of the truck as long as you can match the colour. Just my idea of course.
Cheers, George | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My two cents is to get the original color right and use the best most modern paint you can. Mike  | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | original color, imron paint. the truck ought to outlive you by many years. it will certainly look better. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks again. I count on the experiance of this group to help answer the questions. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I wanted to update you all on the restoration of my truck is moving forward as hey have removed to rusted tank off the truck. When the water tank was removed the truck, the frame wasn't rusted and was in surprisingly great shape. I'll get some pictures next week and share those too!
I'm starting to get excited about the project and it looks like we are going to have a nice experience in the future when we get it finished. Thanks for the help. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | va fire truck, nice truck, maybe ill see you some day at the pa pump primers sucking on the river. what pump is in that chariot and gpm? also i see you paid a visit to the siren guy in az. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | One more comment on the paint- - - -I'd go with DuPont Imron. It's a polyurethane enamel that has the "wet" look for years after it's applied. It won't fade like the original-equipment paint that was applied to the truck when it was new, and it will only require an occasional wash job to keep it loking new. Waxing won't be necessary at all. When Imron was a new product about 30 years ago, it was applied to crop-duster airplanes that couldn't keep paint on them due to the chemical spray. It worked great until it was time to remove the paint for periodic inspection, and none of the normal paint strippers could touch it. It had to be SANDED off, until DuPont could develop a stripper that could take it off! Jerry
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. I think we are going with the Imron paint. The truck has a 500 GPM rate and it still works! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | |
