0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#1403803 03/30/2021 2:30 PM
Does anyone have a source or sizes for the seat bolts and curved washers to mount the middle and rear seats in a 48 suburban? Thanks
Source would be a local hardware store. Size would be a 5/16" carriage bolt, if I remember correctly but I don't remember the length. The curved washers you typically need to make yourself. I did mine by taking a square of aluminum, making a hole down the center, then cutting it in half, then to length.
LMC may also have all of the parts you need.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
