Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Otto Skorzeny, niobrarafun, Guitplayer, MNSmith, NorCal52Suburban, Bill Hanlon), 564 guests, and 1 robot.
Topics126,778
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
Thank you so much for the awesome amount of information on your site. I have recently (last saturday) purchase the following:
1952 Canadian GMC 9430 Pickup Long box (with a Robin hydraulic dump)
Vehicle serial number 2943415032
6 cylinder in-line possibly 216 cubic inch (3.5L)
Engine code XC600988 eng block casting numberGM 3835814 (216 CID)
Cyl head casting number 3835499 (made for 235 CID)
Carburetor Rochester 1 barrel no numbers so far
Transmission casting number GM 591907
Differential Casting number 8699535
Body# 1286
Trim # 394
Paint # 236
Battery 6 volt
Generator Wilson Elec Winnipeg #1100018 6V A.E.
4 Spd standard transmission
Robin 2-ram hydraulic dump box (factory installed)
tires 7.50-17 6 ply original (LT 265/75R16 presently on the truck)
More information than you probably wanted, my plan is to get is safetied and plated then use it as is. I will be using to haul my blacksmithing stuff to the local museum when I do my metal working demonstrations there. I will also use it for scouting and generally as a truck. If I go in parades, I loaded up a bunch scouts, cubs and beavers in the box, haul a parade float behind. Kind of like the "follow me boys" movie.
I am looking for the safety specifications for brake lining thickness, does anyone know what they are? I am also looking for the rear emergency brake cables, they would be the Chev 3800 equivalent, I have not been able to find any so far.
Any help would be appreciated
James Stonehouse
Welcome to the 'bolt. That is almost the perfect "welcome forum" post! Lots of info and pictures.
Please put your parts requests in the swap meet area, as that is the only place to buy, sell or swap parts.
Another quality post.
Real Trucks Rattle
Welcome aboard from a fellow Canadian bolter in Whitby .
I too have a one ton , a 62 c30 panel which I wonder around in a fair bit .
Next time I head out your way I'll look you up and compare notes .
good planning is no substitute for dumb luck
Welcome to the Stovebolt madness. There is no cure! shake
Please check out all the various forums and read the guidelines for site usage posted at the top of General Truck Talk under the post by Cletis titled “Why posts are........”.
Those are beautiful photos of a great truck. You have the motor that was made from 1950 to 52. I have the same one in my 1951 1 Ton. There are some places that can make new parking brake cables if you have the hardware. You might want to give Bill at Bills Truck a call.
1951 1 Ton Completed
AD Addict & Tinkerer
Welcome to the “Bolt”! Great looking truck and I love your plans, old time blacksmith with and old time truck!
Phil
Project Journals
Stovebolt Gallery Forum
Fox Offline
What a solid looking truck. Nice!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Leo Offline
Moderator
Moderator
Welcome to the site. I agree with getting any parts you may need from Bill Peeters at Bill's Truck Shop near Oshawa. Good luck and enjoy the journey.
Leo
Welcome to the Stovebolt and congrats on your purchase. Trucks have a way of "paying their way" while cars are an abcess on a man's pocket book!!!
See you around the garage forums.
i know where Chatham Ont. is, I was born there.
Brian
1955.2 3100 Truck
Hi from Brantford, Jay!
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 2.284s Queries: 15 (0.063s) Memory: 0.6465 MB (Peak: 0.7518 MB) Data Comp: Zlib Server Time: 2025-09-22 17:57:11 UTC
Valid HTML 5 and Valid CSS
