| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 28 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 28 | I anyone familar with the Robin hydraulic lift system (Robin is the name cast into the hydraulic pump, control valve and both lift cylinders)? My GMC 9430 pickup truck has 2 hyraulic rams instead of one. How would I install a lift lock without damage (twisting) the box when lowered onto the lock? I would like to be able to leave the box in the lifted position without danger of having lower itself when at car shows. It appears that the dumpbox is original and not an added feature.
I will get some pictures of the hydraulics tomorrow and add them to this post.
James | | |
