5 members (Stovebolt48, Otto Skorzeny, Youngin' Tut 59, DadsFirstPickup, baldeagle), 65 guests, and 4 robots.
Topics128,180
Posts1,057,148
Members48,464
Hello,
The usual providers have tailgate chains that have a hook on one end and a bolt on the other.
Where does the bolt go? On my bed, the place where the bolt might go, the flange is bent down at a 30-45 degree angle making it hard to put the bolt in straight. I check with all the suppliers and they all have the same setup.
Is this the correct setup for this year truck? I find it hard to believe that both flanges were bent the same amount with use.
Maybe a single shackle instead of the bolt? We’re there different configurations?
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
You might contact www.mar-k.com. I believe they have chains for your 40 model that closely match the original configuration.
Mark
Thanks Mark
