8 members (Gdads51, TUTS 59, msmall, sron48, tclederman, Bigdogg, Nick in Manitou, 1 invisible),
58
Mod | | | Forums66 Topics128,179 Posts1,057,130 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Hello,
The usual providers have tailgate chains that have a hook on one end and a bolt on the other. Where does the bolt go? On my bed, the place where the bolt might go, the flange is bent down at a 30-45 degree angle making it hard to put the bolt in straight. I check with all the suppliers and they all have the same setup. Is this the correct setup for this year truck? I find it hard to believe that both flanges were bent the same amount with use. Maybe a single shackle instead of the bolt? We’re there different configurations?
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | You might contact www.mar-k.com. I believe they have chains for your 40 model that closely match the original configuration. Mark | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 |
