5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
#1402863 03/24/2021 8:40 PM
I have a 1958 stepside with a 283. When the heater fan switch is set to low or medium, the resistors on the back of the switch glow red. Is that normal? It's a standard heater arrangement.
Just a WAG, but no they should not be glowing red... it sounds like you have a short back there.
Another quality post.
Real Trucks Rattle
Moderator, Electrical Bay
The resistors? Do you mean the coiled resistor wire? If that's glowing, then it is a sign of something wrong...I'd suspect the armature grounding out possibly.
~ Jon
Sir Searchalot
Sir Searchalot
They do typically get VERY hot but don't know about actually glowing red. You know those older portable bathroom heaters glow red, why? They are basically resistors. As in: A coiled element array. Just inspect the switch and it's coils to see their solder joints and if they are supposed to be separate, coils not touching. I agree with Rusty Rod and Jon's assessment.
Motor possibly dragging, squirrel cage dragging, shaft bearings need oil drops
