Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (Steelonsteel, klhansen, Lightholder's Dad, Ridgeback, qdub, joetravjr, mick53), 563 guests, and 2 robots.
Topics126,780
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
#1402457 03/22/2021 1:18 AM
My 53 cab is completely sand blasted now. Friday I coated every inch of the inside and outside with Epoxy primer. My question is: Is there any reason to topcoat the epoxy in areas which will never be see or exposed, like behind the dash, the floor behind the seat, etc. etc.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Try an Internet search on "Epoxy primer as a final/topcoat".
One hit: "Most of the flat black rat rods are just ppg dp 90" (Epoxy Primer).
Short answer - NO.
Longer answer. There was very little paint in unexposed areas like under the dash, mainly overspray.
If your cab is on a rotisserie, it may be an opportune time to add some epoxy inside the roof cavities.
No need to topcoat epoxy as it acts as a sealer and primer. John
1949 gmc 1-ton
Epoxy primer left as is, is fine.
Whenever I do subframe work or part repairs on my ute, I clean any rough looking metal and aluminium parts with a rotary wire brush and just do two coats of epoxy primer, years and years later that primer is still solid and no more rusting.
It also gives a good satin look to the part
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.216s Queries: 14 (0.213s) Memory: 0.6134 MB (Peak: 0.6635 MB) Data Comp: Zlib Server Time: 2025-09-22 19:27:01 UTC
Valid HTML 5 and Valid CSS
