8 members (MNSmith, frogfarmer, 1955 1 Series, walter74, Hotrod Lincoln, klhansen, TUTS 59, 1 invisible),
32
Mod | | | Forums66 Topics128,005 Posts1,055,258 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 14 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 14 | A friend of mine had a running 235 with all parts included. He’s offering to me for $200. I can’t imagine that’s a bad price but wanted to ask the experts. Thanks! | | | | | Joined: Feb 2004 Posts: 29,741 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,741 | A little better description than "running" would be in order. Is the vehicle it's coming out of in current use, or will the engine just fire up and keep itself running after a long time in storage? Either way, the price doesn't sound out of bounds, but if you're planning on dropping it into another vehicle without doing some major surgery, you should consider it to be a "rebuildable core". For an engine without some documentation of a recent overhaul, I'd consider the asking price close to the top of what I'd be willing to pay. Read John's story of the "good-running" 261 he put into his big pickup! Jerry
| | | | | Joined: Feb 2021 Posts: 155 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 155 | No expert here but I paid 10x that....lucky find. Good friend. Go for it
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
| | | | | Joined: Dec 2020 Posts: 14 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 14 | Considering an original used filter housing is roughly $100, I’m not sure how I could go wrong. The motor that’s in my truck is numbers matching and I don’t have any intent on replacing it. With the cost of original parts being as high as they are, all I’ll need to do is have to replace two or three things and the spare has payed for itself. It’s on an engine stand and runs with some fuel added to it. Compression is good...... | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Recently, on this site someone(s) were looking for inspection covers, flywheel, 848 head, throttle linkages. If those are included and if you do not desire to store as spares, there is a market. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Hey neighbor. A 235 was made from 1950 to 1962. Beginning 1954, the engine design change a lot for the better. 50 to 53 valve covers are held by 2 bolts in the middle. 54 to 62 are by two screws on each side. 54 to 62 are the years we like. I bought a "running" 1957 235 locally (Lake Norman) for $75. The guy got tired of having it in his basement. The engine had the typical rust build-up inside at the rear water jackets typical of old 216 and 235 engines. With water in the block, opened the rear petcock and nothing came out. Too much rust and probably radiator stop leak. With poor coolant flow the engine overheats causing head warpage. I cleaned out the rust/gunk and put on another head and head gasket. She's good to go. Like Forest Gump says, "life is like a box of chocolates.....". If the seller can't give you good information on the condition of the engine, bid low. If you buy it and the engine is in bad shape, at least you have parts. If the seller really knows his stuff, he will give you detail such as results of a WOT compression test.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | A running 1954 and up engine that has solid lifters or hydraulic lifters is well worth $ 200.00 hear in The South, One caution, over the years I have never pulled a head off a 216 or 235 that didn't have cracks in the head. Magna flux the head and usually the crack's don't go far or into valve holes or piston to water jackets. Clean it up on a bench grinder. rinse completely and put it on. Doc.
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | I am no expert but I paid $250 for a 216 where the seller had a video of the compression test. As it turned out the 216 was a 235 with an 848 head, what luck!
I paid $450 for a 216 that had been rebuilt but had sat for 10 years. | | | | | Joined: Nov 2004 Posts: 2,398 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,398 | If it's a good engine it's a great price.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . A 235 was made from 1950 to 1962. . . A 235 Stovebolt-Six was made from 1941-1962. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Very true. 1941 to 1950 military trucks had 235. In 1946 the Eisenhauer Freighter had two 235 engines.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | ‘41 and later GMC big trucks had 270 engines, also.
Ed
