2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#1401793 03/17/2021 11:43 PM
Replaced a leaking right rear axle seal. What brand/weight gear lube should I use for a stock 1939 Chevy JD Stake Bed 3/4 ton?
Rick
1939 Chevrolet Stake Truck
SAE 90
AD Addict & Tinkerer
Before you go out and buy S.A.E. 90w oil, you must find out if you rear contains hypoid gears. I have a ‘52 3100 and I use 90 weight multi-purpose gear lubricant not the 90 weight mineral oil that I use in my tranny. There is a caution in my shop manual that states “CAUTION: Straight mineral oil must not be used in Hypoid rear axles or two speed axles.”
I would suspect your’s is the same, but we need on of our “experts” to chime in.
Phil
Project Journals
Stovebolt Gallery Forum
1939 3/4T JD - (Commercial -3/4 Ton-3 Stake Pockets - Wheelbase 123 3/4in.)
some information on lubricants - 1940
I could not find 1939 information.
H Online: Content
On a "hypoid" axle, the pinion gear will intersect the ring gear below its centerline. If the driveshaft is below the center of the axle tubes, it's a hypoid axle.
