6 members (sron48, 55shaker, Bill Hanlon, Lightholder's Dad, JW51, Forty9), 196 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#1401494 03/15/2021 7:31 PM
Would appreciate some thoughts on rear axle gears. Current rear gears are 3.55 with a Muncie 420 behind a mildly warmed over 235. Taking off in 2nd (3.57) winds out pretty quick before shifting. I just picked up a TKO600 with the 2.87 first gear and the .82 OD that's gonna run back into a Camaro 10 bolt. Should I stick with the 3.55's or would 3.42's be ok. I don't want to ask too much from the engine and clutch taking off in first gear........or am I just making a big deal out of nothing?
Bodini #1401497 03/15/2021 7:40 PM
Riding in the Passing Lane
I think the 3:55 would be just right for that.
George
1972 Chevy c10 Cheyenne Super
Bodini #1401513 03/15/2021 10:43 PM
Crusing in the Passing Lane
The difference between 3.55 and 3.42 is so small, one probably couldn’t tell the difference.
Stick with what is in there.
Ed
Bodini #1401521 03/16/2021 12:06 AM
Insomniac
Insomniac
Originally Posted by Bodini in the "need for speed" thread
I have a 51 3100 fully restored. The engine is a 235 and the numbers say it's a 58-62 block. I have an SM420 bolted behind it, torque tube rear with the 3.55 setup. The truck has 15 inch wheels with P225x75 tires in the rear. She runs like a dream....up to 50 mph. It would be nice to at least go 55-60 if I get on the highway to go somewhere. If I bump up to 16 inch wheels and tires is that gonna give me 5-10 mph more? Should I go with a "regular" 4 speed, open rear end with lower gears? If so, what easily swapped 4 speed and rear end would you graduates of Truckology recommend? Thanks for any and all ideas.
Bodini
Do you have a Camaro rear end or are you shopping for one? Camaro rear ends came with a variety of gears including 3.55 and 3.42 depending on the year, engine and transmission. Camaro web sites have info on how to ID a rear end.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Bodini #1401542 03/16/2021 2:16 AM
Always tell us what year and model truck you're working on.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Bodini #1401552 03/16/2021 3:28 AM
Moderator, Electrical Bay
J Online: Content
The 3.55 with a 2.87 first will give you a starting line ratio of 10.18. The 3.42 and a 2.87 first is a slr of 9.81. If you're planning on using it as a pickup, I would leave the 3.55 in there. 10.18 is ok for a 235 but honestly speaking that ratio is just barely ok if you're hauling anything heavier than a sheet of plywood and a few 2 x 4s. GM wanted a starting line ratio of 12.08 for the 235 in a 1/2 ton pickup. I would not consider any ratio below 10 unless I had a strong V8 and was setting up to drag race and even then not with a standard transmission. Good luck.
~ Jon
Bodini #1401564 03/16/2021 4:05 AM
Thank you gentlemen. The truck is a 1951 3 window 3100. I picked up the 1978 Camaro rear from a salvage yard and plan on having it rebuilt so no worries in the future. Looks like I'll stick with a 3.55 setup. I don't plan on putting anything in the bed except for a couple lawn chairs when I go to a show.
Bodini #1401614 03/16/2021 4:17 PM
I agree that in your situation the difference between 3.55 and 3.42 is minimal. That is less that 4% difference in driveshaft speed at any road speed. You can get that much difference just due to the different diameters of the various brands for tires in the same nominal size. I doubt if anyone driving a vehicle could tell the difference.
So take the easier/lower cost/less risk route!
Rusty
