2 members (Joe H, PAUL Berardi), 140 guests, and 2 robots.
Topics128,111
Posts1,056,246
Members48,437
Jim C. Blue
Jim C. Blue
Is there any leeway in the width or is it very specific? Wondering if I can broaden my search of affordable tires. My truck has 9.00x20 and the previous truck - a very similar 3-ton - had 8.25x20's.
Alternatively, is there a much more common rim that will fit/just bolt on, without further changes?
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
Helps if we know the year, make and model of the truck in question...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jim C. Blue
Jim C. Blue
Same as in the 'signature'.
1953 GMC 9700 (canada, 450 usa?) 3-ton grain truck.
It will depend on what you intend to do with the truck- - - - -bigger tires allow it to haul heavier loads. Do you plan to do what it was intended to do- - - -haul maximum loads, or just motor around to car shows with the bed empty? If the truck won't be hauling cargo the way it was designed, virtually anything that will hold air will be sufficient.
Jim C. Blue
Jim C. Blue
Thank you.
Will be hauling stuff, but don't expect to ever be at it's max.
