1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | Hello all, Last summer I overhauled and installed the carb from this thread: https://www.stovebolt.com/ubbthread...er-967-to-ported-vacuum.html#Post1364216After tuning, the carb worked great! The choke works great except I assume that when cold, the choke would raise the rpm until it warms up. Right now it doesn't, and will barely idle unless I press the accelerator slightly. It doesn't struggle to idle at all, it's not lean, etc. and responds nicely - the idle is just low. If it's intended to be used with the manual throttle cable that the Rochester used, I can hook that up, but if it's supposed to raise the idle until warm please point me in the right direction. Thank you, Lindsey
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The fast idle cam and spring are located inside the choke housing, assuming you have a 967s with automatic choke. 966s is manual choke.
If the fast idle cam and spring on a 967s are correctly installed, the fast idle spring is good, and the fast idle link adjusted to specification, then the engine should fast idle.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 |
