1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#1400594 03/08/2021 11:05 PM
Hello all,
Last summer I overhauled and installed the carb from this thread:
https://www.stovebolt.com/ubbthread...er-967-to-ported-vacuum.html#Post1364216
After tuning, the carb worked great! The choke works great except I assume that when cold, the choke would raise the rpm until it warms up. Right now it doesn't, and will barely idle unless I press the accelerator slightly. It doesn't struggle to idle at all, it's not lean, etc. and responds nicely - the idle is just low. If it's intended to be used with the manual throttle cable that the Rochester used, I can hook that up, but if it's supposed to raise the idle until warm please point me in the right direction.
Thank you,
Lindsey
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Carburetion specialist
The fast idle cam and spring are located inside the choke housing, assuming you have a 967s with automatic choke. 966s is manual choke.
If the fast idle cam and spring on a 967s are correctly installed, the fast idle spring is good, and the fast idle link adjusted to specification, then the engine should fast idle.
Jon.
The Carburetor Shop
Ok thank you
