1 members (baldeagle),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | this cabover is a dump truck with a 327 !!! rare or just another potential restoration. check my webshots last photo | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Way cool.... I've never seen one like it!
Andrew
A man is like an old truck... He will rust out before he wears out...
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Tilt Cab G.M. COE's of, 1960-mid 70's(styling stayed the same)are not as "Rare", as the earlier COE's, but, they're numbers are definitely dwindling.The Chevrolet version, is a little more "rare", than the GMC version. And if you should happen to find one of those V-12 equipted GMC Tilt Cabs, you'd really have something. Alot of them, were used as, straight trucks, for textile mills in my area, & alot used as Fire Trucks, & dumpster trucks. Check out http://www.6066gmctrucks.org/Lmodel.htm , for more info., on them. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | DON'T KNOW THE YEAR BUT WITTH THE HEADLIGHTS I WILL GUESS,58-59,, THE THING IS SHORTER THAN MY EXTENDED CAB 1/2 TON.? | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | YEA COOL TRUCKS ON YER SITE,,THIS ONE IS A CHEVY ,MAYBEE THE OLDER CHAP MIGHT PART WITH HER IN A FEW YEARS! | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Please don't Yell in your posts  | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | I THOUGHT I WAS TALKING TO OLDER GENTS WHO HAVENT CHANGED THEIR BATTERIES IN THIER HEARRIN AIDS! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Andre, 1960 was the first year for the Chevy, & GMC Tilt Cabs. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If it has 4 headlights, chances are it's a '60-'63. What series is it. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | they are cool!  | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | How about a 69 GMC with Toro'flow Diesel? It is same, but has single lights. Also, earlier models had hanging odd positioned pedals under dash for clutch and brake. Mine are into floor and MC is under cab. Have to tilt up to see. Really a PIA to work on, which I am having to do soon. Mine was a Firetruck at one time, nice and Red!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
