5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#139853 02/07/2005 9:48 AM
"MONGO"
"MONGO"
Been looking for a Big Bolt for some time, and all of them so far have been too far for me to consider getting them. So I was excited to find this one about a mile from our farm. The owner says it runs and drives but the brakes are soft. It's a 1953 6400 with a 4 speed tranny, 2 speed rear, Steel flatbed that dumps. Just what I was looking for. Only bummer is it'll be about 2 weeks before I get back up there to check it out in person (2 hours away) so I hope it doesn't sell before then. (And I'm not telling you guys where it is!) wink
Looking for a checklist of stuff to check out on it, specifically stuff that's different on the big bolts.
Also if I do get the chance to test drive it and maybe drive it down the back gravel roads to our place if I get it, can you guys give me a crash course on the 4 Speed 2 Speed rear setup?
What will it likely have a 235 or a 261?
I have no short term goals for the truck; if it runs well and drives it might get some minor work around the farm (after I go through the brakes). I'd like to go through it enough to use it to haul rock from the old quarry that's on the farm to the location where we want to build our house someday and the thought of turning it into a ramp style car hauler has crossed my mind too (Just cause I always seem to be moving stuff around).
Thanks in advance O' wrenchers of the big bolts.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#139854 02/07/2005 9:49 AM
"MONGO"
"MONGO"
Forgot..
Here's a picture let me know what you guys think.
Future MONGO Hauler???
MONGO
Mongo's Garage
#139855 02/07/2005 1:58 PM
KC: Good looking truck!! Kinda what I'm looking for in a paint truck. I'll bet that bed is newer than the cab. 2 speeds are easy, just drive them like a stick, The old Int. I use to drive on the farm you would start in low range then blip the clutch and pull the botton it would go into high.
Around the farm low range will be all you need especially hauling a load of stone. Oh if its a 2 lever floor shift just shift from low to high with clutch also. Raise the bed and see if its raising smooth (not jerky). Raise the bed all the way then get out and check cylinder. If start to lower by itself could be bad seals, check hydraulic hoses for leaks, cracks, fittings. Just becareful the bed doesn't come down on your head.
Got any good "old" farm buddies take them with you. But, as good as that truck looks in the picture somebody has taken care of it. Wish I was there I can point and show you better than I can explain on this computer. Ben
popcorn The Truth is Out There (Nice find)
#139856 02/07/2005 3:57 PM
Junior Member
Junior Member
groovey truck. if you go lookin around at the cyclinder, frame, rear end with that box raised make sure and through a wood post or something else in the v made by the box and the frame at the rear pivot point and let the box down on it so you don't get a big crushing suprise if the hydraulics let go. here is a picture (i hope) of a post in my dump truck holding the box. the post is behind the railroad tie that is stuck in for good measure. [img]http://community.webshots.com/photo/265109366/265118965qhlRsq[/img]
#139857 02/07/2005 3:58 PM
Junior Member
Junior Member
well that didn't work, lets try a link instead.
#139858 02/08/2005 12:39 AM
Riding in the Passing Lane
Looks like a good solid truck KC. I,ll go look at it with you. I grew up working on the larger trucks. I can show you how to work the 2 speed easier than trying to explain it. I,m retired so I have a little extra time. smile
1972 Chevy c10 Cheyenne Super
#139859 02/08/2005 2:08 AM
Looks great!
My '52 6400 is a 235. If its empty you'll not need the low gear in the rear. If the 2-speed is a red knob on the shifter its easy to shift. Get the truck in motion, pull the knob up, and then put the clutch in and out. You'll be in high.
If you're thinking you're driving it home, plan on more than 2 hours... And get comfortable with reaching for the brake lever! Soft brakes might suddenly mean no brakes.
#139860 02/08/2005 2:13 AM
Dang, that's exactly what I've been looking for! If it doesn't pan out, keep me in mind! wink
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#139861 02/08/2005 5:16 AM
looks like an easy restore. if the engine is any good at all ya got a workhorse that ought to be around for years to come.
#139862 02/08/2005 5:43 AM
U
U Offline
Hey, I know where that truck is, For sale eh?! Naw, just kidding. Very nice ride, you will be very happy. Welcome to the Big Bolts!
Aloha,
Keoni
#139863 02/08/2005 5:55 PM
"MONGO"
"MONGO"
Thanks for the tips guys the truck is about a mile from our farm which is 2 hours from KC where I live so I'm trying to arrange things so I can make a run up there this weekend. I should be able to get it to the farm on just gravel roads at low speeds.
Wrenchbender: Would love for you to go but it's quite a trip and I might spend the weekend driving it around the fields at the farm.. smile
My father in law went by sunday afternoon and looked it over for me guess the seller didn't have time to try to sell it to him, so he looked at it on his own. He says it's got all the normal AD rust but looks solid over all. I can't wait to go see it.
Mongo
Mongo's Garage
#139864 02/08/2005 9:03 PM
I see. I thought it was in the Indep. area. I do want to get with you in better weather & take some photos of my 70 stepside. smile
